Ir para o conteúdo principal
QFX IT-437 Motherboard Replacement
O que você precisa
  1. QFX IT-437 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: passo 2, imagem 1 %32 QFX IT-437 Motherboard Replacement: passo 2, imagem 2 %32
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: passo 3, imagem 1 %32
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: passo 4, imagem 1 %32
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: passo 5, imagem 1 %32
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: passo 6, imagem 1 %32
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: passo 7, imagem 1 %32
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: passo 8, imagem 1 %32
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
Conclusão
Douglas
Membro desde: 01/28/15
482 Reputação
Autoria de 4 guias
Equipe
Pasco Hernando, Team 5-2, Prince Winter 2015 Membro de Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
Membros da 6
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 245
