Ir para o conteúdo principal
QFX IT-437 Camera Assembly Replacement
O que você precisa
  1. QFX IT-437 Camera Assembly Replacement, Camera Assembly: passo 1, imagem 1 %32
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Camera Assembly Replacement: passo 2, imagem 1 %32 QFX IT-437 Camera Assembly Replacement: passo 2, imagem 2 %32
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Camera Assembly Replacement: passo 3, imagem 1 %32
    • Use the spudger to unhinge the camera from its socket.
  4. QFX IT-437 Camera Assembly Replacement: passo 4, imagem 1 %32
    • Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
Conclusão
Douglas
Membro desde: 01/28/15
482 Reputação
Autoria de 4 guias
Equipe
Pasco Hernando, Team 5-2, Prince Winter 2015 Membro de Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
Membros da 6
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 107
