Ir para o conteúdo principal
QFX IT-437 Battery Replacement
O que você precisa
  1. QFX IT-437 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: passo 2, imagem 1 %32 QFX IT-437 Battery Replacement: passo 2, imagem 2 %32
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: passo 3, imagem 1 %32
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: passo 4, imagem 1 %32
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: passo 5, imagem 1 %32
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Douglas
Membro desde: 01/28/15
482 Reputação
Autoria de 4 guias
Equipe
Pasco Hernando, Team 5-2, Prince Winter 2015 Membro de Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
Membros da 6
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 381
