Introdução
In This Guide We Will Go Over How To Replace Your Flipper Zero Shell With A Transparent One, This Is Gonna Look Awesome!
O que você precisa
Use A PH0 Screwdriver To Open/Remove The Back Part Of The Shell.
Using Your Fingernail, Spudger, Guitar Pick, Or Any Other Prying Tool, Take Off The Back Shell.
Using Your PH0 Screwdriver Unscrew The Two Short Screws Holding The Internals Down To The Shell.
Put Your Flipper's Internals Into The New Shell.
Screw The Three Short Screws Back Into Place.
Using Your, Spudger, Guitar Pick, Flathead Screwdriver, Or Any Other Prying Tool, Take Off The NFC Board
Put The Two Shells Together And Then Insert The Four Long Screws Into The Screw Holes And Tighten Them.
