Ir para o conteúdo principal
Puritan Bennett 540 Alarm Resetting Technique
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
  1. Puritan Bennett 540 Alarm Resetting Technique, Puritan Bennett 540 Alarm Resetting Technique: passo 1, imagem 1 %32
    • Press the MENU Key to access the Alarm Settings Menu.
  2. Puritan Bennett 540 Alarm Resetting Technique: passo 2, imagem 1 %32 Puritan Bennett 540 Alarm Resetting Technique: passo 2, imagem 2 %32
    • Press the down arrow key to position the cursor on the “Alarm Logs” line, if this is not already the case.
  3. Puritan Bennett 540 Alarm Resetting Technique: passo 3, imagem 1 %32
    • Press the Enter key to confirm the selection of the Alarm Menu.
  4. Puritan Bennett 540 Alarm Resetting Technique: passo 4, imagem 1 %32 Puritan Bennett 540 Alarm Resetting Technique: passo 4, imagem 2 %32
    • Press the up arrow key to position the cursor on the “Reactivate Paused Alarm” line. The following graphic shows the resulting display.
  5. Puritan Bennett 540 Alarm Resetting Technique: passo 5, imagem 1 %32 Puritan Bennett 540 Alarm Resetting Technique: passo 5, imagem 2 %32 Puritan Bennett 540 Alarm Resetting Technique: passo 5, imagem 3 %32
    • Press the Enter key for at least three (3) seconds. The following events occur:
    • A “beep” sounds.
    • An audible alarm sounds.
    • An alarm indicator illuminates.
    • The messages of all active alarms are displayed in a loop in the Ventilation and Alarm menus.
    • The Audio Paused symbol disappears (if it was displayed).
    • The Alarm Paused symbol disappears.
Conclusão
There is no need to reassemble the device, but if the condition persists you can try resetting the audio again.
kerribyrne
Membro desde: 04/08/20
267 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G7, Paton Spring 2020 Membro de Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 113
