Ir para o conteúdo principal
Puritan Bennett 540 Air Inlet Filter Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Puritan Bennett 540  Air Inlet Filter Replacement, Air Inlet Filter: passo 1, imagem 1 %32
    • Hold the filter between your fingers and pinch. Pull the filter outwards (towards you).
  2. Puritan Bennett 540  Air Inlet Filter Replacement: passo 2, imagem 1 %32
    • Remove the filter and discard it. Do not save it. When removed, it should look like the attached image.
    • Place the new filter in the device by making sure that:
    • a. The fine particle side of the filter faces outwards, away from the ventilator.
    • b. The filter is properly installed in its housing. Proper installation of the filter prevents particles from entering the device. Remember that the air inlet filter is not reusable; do not wash, clean, or reuse it!
Conclusão
There is no reassembly needed after replacing the inlet filter.
kerribyrne
Membro desde: 04/08/20
267 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G7, Paton Spring 2020 Membro de Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 81
