Ir para o conteúdo principal
Protocol Vento Motor Replacement
O que você precisa
  1. Protocol Vento Motor Replacement, Battery: passo 1, imagem 1 %32
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: passo 2, imagem 1 %32
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: passo 3, imagem 1 %32
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: passo 4, imagem 1 %32 Protocol Vento Motor Replacement: passo 4, imagem 2 %32
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: passo 5, imagem 1 %32
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: passo 6, imagem 1 %32 Protocol Vento Motor Replacement: passo 6, imagem 2 %32
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: passo 7, imagem 1 %32 Protocol Vento Motor Replacement: passo 7, imagem 2 %32
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: passo 8, imagem 1 %32 Protocol Vento Motor Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
Conclusão
4 outras pessoas executaram este guia.
Maria Larcomb
Membro desde: 02/15/18
926 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2018 Membro de USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Membros
Autoria de 6 guias
2Comentários do guia
Please send me motor description
suresh virji - Responder
send me protocol vento motor
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 759
