Ir para o conteúdo principal
Protocol Slipstream EVO Propeller blades Replacement
O que você precisa
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: passo 1, imagem 1 %32
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: passo 2, imagem 1 %32 Protocol Slipstream EVO Propeller blades Replacement: passo 2, imagem 2 %32
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: passo 3, imagem 1 %32 Protocol Slipstream EVO Propeller blades Replacement: passo 3, imagem 2 %32 Protocol Slipstream EVO Propeller blades Replacement: passo 3, imagem 3 %32
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Conclusão
Michael Dang
Membro desde: 04/10/17
301 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G3, Liner Spring 2017 Membro de UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 605
