Ir para o conteúdo principal
Protocol Slipstream EVO Propeller Guards Replacement
O que você precisa
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: passo 1, imagem 1 %32
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: passo 2, imagem 1 %32 Protocol Slipstream EVO Propeller Guards Replacement: passo 2, imagem 2 %32
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: passo 3, imagem 1 %32 Protocol Slipstream EVO Propeller Guards Replacement: passo 3, imagem 2 %32
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Conclusão
Michael Dang
Membro desde: 04/10/17
301 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G3, Liner Spring 2017 Membro de UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 233
