Introdução
This guide will explain how to replace a motor of the Protocol Kaptur GPS drone.
O que você precisa
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Remove the 4x 7mm Phillips head screws on the outside of the shell, and the 2x 5mm Phillips head screws from the middle, then remove the back part of the housing.
Remove the two hidden screws at the bottom, and the white power button.
9 outras pessoas executaram este guia.
12Comentários do guia
What size and rpm does it take, but also is there a way to upgrade the motors for more punch?
Thank you.for your information and time to make my grandson
What size is the main gear??
2.0
I believe
Anyone else having a problem with the props twisting on the shaft during flight
