Introdução
This guide will walk you through the 16 steps to replace the top shell of the Drone.
O que você precisa
Ferramenta utilizada nesse passo:Heavy-Duty Spudger$4.99
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Quase terminado!
Conclusão
