Ir para o conteúdo principal
Protocol Galileo Stealth Motor Replacement
O que você precisa
  1. Protocol Galileo Stealth Motor Replacement, Propeller: passo 1, imagem 1 %32
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Motor Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Motor Replacement: passo 3, imagem 1 %32
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Motor Replacement: passo 4, imagem 1 %32
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Motor Replacement, Housing: passo 5, imagem 1 %32 Protocol Galileo Stealth Motor Replacement, Housing: passo 5, imagem 2 %32
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Motor Replacement: passo 6, imagem 1 %32
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Motor Replacement, Motor: passo 7, imagem 1 %32 Protocol Galileo Stealth Motor Replacement, Motor: passo 7, imagem 2 %32
    • Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
    • Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
    • Place screws in a safe place to prevent misplacing them.
  8. Protocol Galileo Stealth Motor Replacement: passo 8, imagem 1 %32
    • Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
    • Place the screws in a safe place to prevent misplacing them.
  9. Protocol Galileo Stealth Motor Replacement: passo 9, imagem 1 %32
    • Remove the motor cover by lightly pulling it away from the drone.
  10. Protocol Galileo Stealth Motor Replacement: passo 10, imagem 1 %32 Protocol Galileo Stealth Motor Replacement: passo 10, imagem 2 %32
    • Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
    • This plug can be a bit difficult to remove, but it does not require much force to remove.
    • Avoid damaging the plug and wires when unclipping wire plug.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Selting
Membro desde: 02/15/18
432 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,094
