Introdução
This guide will walk you through how remove the drone motors from the lower housing. Minimal tooling is required; however, prerequisite steps are required. This guide is useful for replacing a motor that may be defective or damaged.
O que você precisa
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
Uma outra pessoa concluiu este guia.
