Ir para o conteúdo principal
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
O que você precisa
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: passo 1, imagem 1 %32 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: passo 1, imagem 2 %32
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: passo 2, imagem 1 %32
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): passo 3, imagem 1 %32
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: passo 4, imagem 1 %32
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: passo 5, imagem 1 %32
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Conclusão
Matthew Selting
Membro desde: 02/15/18
432 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 157
