Pular para o conteúdo principal
Introdução
This guide will walk you through how to replace the light emitting diodes (LED) on the drone. Minimal tooling is required, but the risk of damaging the drone is greater then many of the other guides if each step is not followed and executed with extra care.
Peças
Nenhum componente especificado.
  1. Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit. Take care to place the screws in a safe place to prevent losing them.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Separate the upper and lower housing units by lightly pulling the two housing units apart.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove  6mm Phillips #0 screw from the LED strip.
    • Remove 6mm Phillips #0 screw from the LED strip.
  5. Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  6. Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Conclusão
Matthew Selting
Membro desde: 15-02-2018
411 reputação
4 Guias de autoria
Equipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 46
