Pular para o conteúdo principal
Introdução
This guide will walk you through how to separate the upper and lower housing units of the drone. Minimal tooling is required; however, prerequisite steps are required. This guide is useful for accessing internal components of the drone.
Peças
Nenhum componente especificado.
  1. Remove the chrome shaft cover by lightly pulling it away from the drone.
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the propeller stop from shaft by lightly pulling it away from the drone.
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  5. Remove the propeller from shaft by lightly pulling it away from the drone.
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  6. Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit. Take care to place the screws in a safe place to prevent losing them.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  7. Separate the upper and lower housing units by lightly pulling the two housing units apart.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Conclusão
Matthew Selting
Membro desde: 15-02-2018
411 reputação
4 Guias de autoria
Equipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 55
