Introdução
Is a motor on your drone spinning but not causing the propeller to spin? Replacing the pinion gear as shown in this guide may help.
O que você precisa
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Quase terminado!
Conclusão
