Ir para o conteúdo principal
Protocol Galileo Motor Replacement
O que você precisa
  1. Protocol Galileo Motor Replacement, Battery: passo 1, imagem 1 %32
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Motor Replacement: passo 2, imagem 1 %32 Protocol Galileo Motor Replacement: passo 2, imagem 2 %32
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Motor Replacement: passo 3, imagem 1 %32
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Motor Replacement, Propeller: passo 4, imagem 1 %32 Protocol Galileo Motor Replacement, Propeller: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Spudger
    Comprar
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Motor Replacement: passo 5, imagem 1 %32
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Motor Replacement: passo 6, imagem 1 %32
    Comprar
  7. Protocol Galileo Motor Replacement: passo 7, imagem 1 %32
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Motor Replacement: passo 8, imagem 1 %32 Protocol Galileo Motor Replacement: passo 8, imagem 2 %32
    • Pull off propeller.
  9. Protocol Galileo Motor Replacement, Top Shell: passo 9, imagem 1 %32 Protocol Galileo Motor Replacement, Top Shell: passo 9, imagem 2 %32 Protocol Galileo Motor Replacement, Top Shell: passo 9, imagem 3 %32
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Motor Replacement: passo 10, imagem 1 %32 Protocol Galileo Motor Replacement: passo 10, imagem 2 %32
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Motor Replacement: passo 11, imagem 1 %32 Protocol Galileo Motor Replacement: passo 11, imagem 2 %32 Protocol Galileo Motor Replacement: passo 11, imagem 3 %32
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Motor Replacement: passo 12, imagem 1 %32 Protocol Galileo Motor Replacement: passo 12, imagem 2 %32
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Motor Replacement: passo 13, imagem 1 %32 Protocol Galileo Motor Replacement: passo 13, imagem 2 %32 Protocol Galileo Motor Replacement: passo 13, imagem 3 %32
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Motor Replacement: passo 14, imagem 1 %32
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Motor Replacement: passo 15, imagem 1 %32 Protocol Galileo Motor Replacement: passo 15, imagem 2 %32
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Motor Replacement: passo 16, imagem 1 %32 Protocol Galileo Motor Replacement: passo 16, imagem 2 %32 Protocol Galileo Motor Replacement: passo 16, imagem 3 %32
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Motor Replacement, Pinion Gear: passo 17, imagem 1 %32
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Motor Replacement: passo 18, imagem 1 %32 Protocol Galileo Motor Replacement: passo 18, imagem 2 %32
    • Slide the pinion gear off of the motor assembly.
  19. Protocol Galileo Motor Replacement, Motor: passo 19, imagem 1 %32 Protocol Galileo Motor Replacement, Motor: passo 19, imagem 2 %32
    • Remove the two 4mm Philips screws from the motor.
    • Separate the motor from the plastic motor holder.
Conclusão
Thomas Ramey
Membro desde: 02/03/17
301 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 2-3, Rose Winter 2017 Membro de UW Tacoma, Team 2-3, Rose Winter 2017
UWT-ROSE-W17S2G3
Membros da 4
Autoria de 5 guias
Um comentário
what I need to know is where can I buy the plastic motor holder. This would be for a Galileo stealth drone. can someone please help me with this. markkermoyan@gmail.com
mark kermoyan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 695
