Ir para o conteúdo principal
Protocol Dronium Two HD Camera Replacement
O que você precisa
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: passo 1, imagem 1 %32
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: passo 2, imagem 1 %32 Protocol Dronium Two HD Camera Replacement: passo 2, imagem 2 %32
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: passo 3, imagem 1 %32 Protocol Dronium Two HD Camera Replacement, HD Camera: passo 3, imagem 2 %32
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: passo 4, imagem 1 %32 Protocol Dronium Two HD Camera Replacement: passo 4, imagem 2 %32
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: passo 5, imagem 1 %32 Protocol Dronium Two HD Camera Replacement: passo 5, imagem 2 %32
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: passo 6, imagem 1 %32
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 219
