Introdução
In this guide you will learn how to remove and replace the top two propellor blades of the Gyro-X. This is a common procedure, because crashing your Gyro-X will often result in propellor damage. To remove the propellors you will only need to remove 4 small screws. Be careful not to lose these after removal.
O que você precisa
Uma outra pessoa concluiu este guia.
