Ir para o conteúdo principal
Propel Gyro-X Drive Gears Replacement
O que você precisa
  1. Propel Gyro-X Drive Gears Replacement, Top Propellor Blades: passo 1, imagem 1 %32
    • Stabilizing links are easy to break. Be gentle when prying them off.
    • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
  2. Propel Gyro-X Drive Gears Replacement: passo 2, imagem 1 %32 Propel Gyro-X Drive Gears Replacement: passo 2, imagem 2 %32
    • Remove the two 6.0 mm Phillips #00 screws from the rotors.
  3. Propel Gyro-X Drive Gears Replacement: passo 3, imagem 1 %32 Propel Gyro-X Drive Gears Replacement: passo 3, imagem 2 %32
    • Pull the rotors away from the mounting brackets.
  4. Propel Gyro-X Drive Gears Replacement, Bottom Propellor Blades: passo 4, imagem 1 %32
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
  5. Propel Gyro-X Drive Gears Replacement, Outer Shell: passo 5, imagem 1 %32
    • Locate the nubs on either side of the helicopter.
  6. Propel Gyro-X Drive Gears Replacement: passo 6, imagem 1 %32
    • Pull the body shell off of the nubs on both sides.
  7. Propel Gyro-X Drive Gears Replacement: passo 7, imagem 1 %32 Propel Gyro-X Drive Gears Replacement: passo 7, imagem 2 %32
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
  8. Propel Gyro-X Drive Gears Replacement, Drive Gears: passo 8, imagem 1 %32
    • Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
  9. Propel Gyro-X Drive Gears Replacement: passo 9, imagem 1 %32
    • Remove the 4 mm Phillips #00 screw from the tail.
  10. Propel Gyro-X Drive Gears Replacement: passo 10, imagem 1 %32 Propel Gyro-X Drive Gears Replacement: passo 10, imagem 2 %32 Propel Gyro-X Drive Gears Replacement: passo 10, imagem 3 %32
    • Use your fingers to free the motor casing from the body, by bending the plastic body casing outwards at each of the four nubs.
    • Pull the motor casing upwards from the body.
    • The drive gear will slide out when you lift the motor casing.
Conclusão
Jack Jenner
Membro desde: 04/08/15
293 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-2, Forte Spring 2015 Membro de Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 2,963
