Ir para o conteúdo principal
Propane Grill Regulator & Hose Replacement
O que você precisa
  1. Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: passo 1, imagem 1 %32 Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: passo 1, imagem 2 %32
    • Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
    • Breathing in or swallowing propane can harm your health.
    • Turn the knob on the hose counter clockwise to disconnect it from the tank.
  2. Propane Grill Regulator & Hose Replacement: passo 2, imagem 1 %32 Propane Grill Regulator & Hose Replacement: passo 2, imagem 2 %32
    • Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
    • Replace the old battery with a new one.
  3. Propane Grill Regulator & Hose Replacement: passo 3, imagem 1 %32
    • Locate the orifice that connects the base of the grill and the hose to one another.
    • An orifice is a valve commonly found on gas powered home products. This allows the gas to pass through from the source (i.e the propane tank) and burn properly.
    • Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
  4. Propane Grill Regulator & Hose Replacement: passo 4, imagem 1 %32 Propane Grill Regulator & Hose Replacement: passo 4, imagem 2 %32
    • Begin hand tightening the new hose to the nut that is connected to the orifice.
    • If you over tighten the bolt or do not hand tighten it first, you could cross thread the orifice and create more problems for the grill.
    • Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Rob Fillion - Responder
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 50
Duração total: 6,855
