Ir para o conteúdo principal
Promowide SP1790 Charging Port Replacement
O que você precisa
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: passo 1, imagem 1 %32
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: passo 2, imagem 1 %32
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: passo 3, imagem 1 %32
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: passo 4, imagem 1 %32
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: passo 5, imagem 1 %32
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: passo 6, imagem 1 %32
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: passo 7, imagem 1 %32
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: passo 8, imagem 1 %32
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: passo 9, imagem 1 %32
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 955
