Ir para o conteúdo principal
Projector NEC VT660 Disassembly
O que você precisa
  1. Projector NEC VT660 Disassembly, Remove lamp cover: passo 1, imagem 1 %32 Projector NEC VT660 Disassembly, Remove lamp cover: passo 1, imagem 2 %32
    • Unscrew the screw and remove the cover.
  2. Projector NEC VT660 Disassembly, Remove lamp: passo 2, imagem 1 %32 Projector NEC VT660 Disassembly, Remove lamp: passo 2, imagem 2 %32
    • Unscrew the two screws that are holding the lamp in place.
    • Pull the lamp out.
  3. Projector NEC VT660 Disassembly, Housing disassembly: passo 3, imagem 1 %32 Projector NEC VT660 Disassembly, Housing disassembly: passo 3, imagem 2 %32 Projector NEC VT660 Disassembly, Housing disassembly: passo 3, imagem 3 %32
    • Remove 5 screws from the bottom.
    • Remove 1 screw from the back.
    • Slowly lift the upper housing and disconnect the connector.
    • Do not lift the upper housing too quickly as it could damage the connector cable.
  4. Projector NEC VT660 Disassembly, Removing fan: passo 4, imagem 1 %32 Projector NEC VT660 Disassembly, Removing fan: passo 4, imagem 2 %32 Projector NEC VT660 Disassembly, Removing fan: passo 4, imagem 3 %32
    • After removing the upper housing. Turn the projector to see the fan.
    • Unscrew two screws from each side of the fan holder.
    • Remove the fan from holder by unscrewing the two screws.
    • Carefully take out the fan. Keep an eye on the wires that go through the holder.
Conclusão
Uma outra pessoa concluiu este guia.
Klemen Hodžić
Membro desde: 11/01/20
694 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 357
