Ir para o conteúdo principal
Programming the Smart Key
  1. Programming the Smart Key, Enter Settings: passo 1, imagem 1 %32
    • With the Clix on and past the start-up screen, go down to settings.
    • Select it by pressing right.
    Pergunte ao FixBot
    Comentar
  2. Programming the Smart Key, Enter Smart Key: passo 2, imagem 1 %32
    • In settings, go down and press right to select 'Smart Key'.
    Pergunte ao FixBot
    Comentar
  3. Programming the Smart Key, Select an operation: passo 3, imagem 1 %32
    • select the function of your choice by pressing right on anything in the Smart key options menu.
    • The next steps are rundowns of all the operations of the Smart Key.
    Pergunte ao FixBot
    Comentar
  4. Programming the Smart Key, OP-1: Home: passo 4, imagem 1 %32
    • Will send the user straight to the Clix home screen when pressed.
    Pergunte ao FixBot
    Comentar
  5. Programming the Smart Key, OP-2: Play/Pause: passo 5, imagem 1 %32
    • As it says, plays or pauses any music or audio that is playing.
    Pergunte ao FixBot
    Comentar
  6. Programming the Smart Key, OP-3: Shuffle all: passo 6, imagem 1 %32
    • Plays and shuffles all music and audio books when pressed.
    • Note the symbol in the top right of the screen that indicates that it's in shuffle mode.
    Pergunte ao FixBot
    Comentar
  7. Programming the Smart Key, OP-4: Display Orientation: passo 7, imagem 1 %32
    • Rotates the display from landscape to portrait mode, and vice versa when pressed.
    Pergunte ao FixBot
    Comentar
  8. Programming the Smart Key, OP-5: Start/Stop Recording: passo 8, imagem 1 %32
    • Takes the user to the recorder program and automatically starts recording voice.
    Pergunte ao FixBot
    Comentar
  9. Programming the Smart Key, OP-6: Add to Quick List: passo 9, imagem 1 %32
    • when pressed, the Smart Key adds whatever you may be listening to into the Quick List playlist on the Clix.
    Pergunte ao FixBot
    Comentar
Conclusão
Now that you know what to do with the Smart Key, you can enjoy the convenience of your selected feature!
Rando_GUY
Membro desde: 05/17/23
853 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 309
