Introdução
The solenoid's job is to cut the power allocated to the heating elements and release the latch, springing the toast upward. Consistently burnt toast no matter what desired setting applied is a good sign that the solenoid needs to be repaired in some way.
Peças
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
Locate the metal knob protruding from the removed circuit board.
Remove the 10mm nut with an equally sized wrench and replace the now removable solenoid.
