Ir para o conteúdo principal
Problem with navigation in the Android System Recovery menu
Vídeo de Apresentação
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, imagem 1 %32 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, imagem 2 %32 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, imagem 3 %32
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
    No volume buttons and home button wont navigate
    Joy - Responder
  2. Problem with navigation in the Android System Recovery menu: passo 2, imagem 1 %32 Problem with navigation in the Android System Recovery menu: passo 2, imagem 2 %32
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
Conclusão
35 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.182 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.521 guias
13 comentários
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - Responder
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - Responder
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - Responder
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - Responder
This is a great post. Helped me easily navigate the recovery menu on my bricked phone.
fsmanchies - Responder
By contrast, i still like to using the recovery tool to restore lost files from Android phone ,it can scan some of deleted photos from my Android SD card,http://www.android-rescuer.com/recover-d...
Tamster - Responder
Yes it worked thank you
Jesse Brook - Responder
Thanks for sharing so many interesting technical articles. I have read most of them and gain lots knowledge. And I want to share some technical articles with your reader. And I also know a good tool do well in navigation in the Android phones, or you can just search on Google with FoneDog for more detail.
Agle - Responder
doesn’t work for me please help me!
Bruce LUI - Responder
That was exactly my problem !! And I followed your steps and it worked very well, thanks a lot
Safa Fituri - Responder
Mine still gets stuck on the T-Mobile boot screen.
AlwaysAStudent - Responder
J'ai oublié mot de passe tablette Samsung A7 à l'aide
Tulipe 64 Bouquet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 43
Duração total: 74,281
