Ir para o conteúdo principal
ProScan PLT7223G Speakers Replacement
O que você precisa
  1. ProScan PLT7223G Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Speakers Replacement: passo 2, imagem 1 %32
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Speakers Replacement: passo 3, imagem 1 %32
    • Pull back the protective tape from the two wires that connect the speakers to the motherboard.
  4. ProScan PLT7223G Speakers Replacement: passo 4, imagem 1 %32
    • Use the soldering tool to remove speaker wires from motherboard.
    • Soldering tool will get hot, handle with care.
  5. ProScan PLT7223G Speakers Replacement: passo 5, imagem 1 %32 ProScan PLT7223G Speakers Replacement: passo 5, imagem 2 %32
    • If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 305
