Ir para o conteúdo principal
ProScan PLT7223G Motherboard Replacement
O que você precisa
  1. ProScan PLT7223G Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
  2. ProScan PLT7223G Motherboard Replacement: passo 2, imagem 1 %32
    • Use the blue opening tool to pry the tablet open.
  3. ProScan PLT7223G Motherboard Replacement: passo 3, imagem 1 %32 ProScan PLT7223G Motherboard Replacement: passo 3, imagem 2 %32
    • Remove all yellow tape from the motherboard.
  4. ProScan PLT7223G Motherboard Replacement: passo 4, imagem 1 %32 ProScan PLT7223G Motherboard Replacement: passo 4, imagem 2 %32 ProScan PLT7223G Motherboard Replacement: passo 4, imagem 3 %32
    • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
    • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
  5. ProScan PLT7223G Motherboard Replacement: passo 5, imagem 1 %32 ProScan PLT7223G Motherboard Replacement: passo 5, imagem 2 %32 ProScan PLT7223G Motherboard Replacement: passo 5, imagem 3 %32
    • Lift all three ZIF connectors to disconnect the ribbon wire.
  6. ProScan PLT7223G Motherboard Replacement: passo 6, imagem 1 %32
    • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
  7. ProScan PLT7223G Motherboard Replacement: passo 7, imagem 1 %32
    • Lift the motherboard off the device.
Conclusão
1Comentário do guia
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 1,596
