Introdução
This guide will show you how to remove the plastic casing from the lower half of the iHome iP37. This step is necessary in order to replace any components housed in the lower half.
O que você precisa
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
