Introdução
Prying the exterior housing takes some force but is not difficult. If you are replacing the speaker unit, pry off the upper half.
O que você precisa
Ferramenta utilizada nesse passo:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Quase terminado!
To reassemble your device, apply double-sided tape or adhesive on the existing glue and fit the housing back on.
Conclusão
