Ir para o conteúdo principal
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
O que você precisa
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: passo 1, imagem 1 %32 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: passo 1, imagem 2 %32
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 2, imagem 1 %32
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 3, imagem 1 %32 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 3, imagem 2 %32 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 3, imagem 3 %32
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 4, imagem 1 %32
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 5, imagem 1 %32 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 5, imagem 2 %32 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 5, imagem 3 %32
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 6, imagem 1 %32
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: passo 7, imagem 1 %32
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
Conclusão
Thank you for using this guide!
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 139
Últimos 30 dias: 428
Duração total: 1,700
