Ir para o conteúdo principal
PowerShot G7 X Mark II LCD Screen Replacement
O que você precisa
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: passo 2, imagem 1 %32
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove Back panel from LCD screen.
    • Use a spudger tool to release ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
  4. PowerShot G7 X Mark II LCD Screen Replacement: passo 4, imagem 1 %32
    • The screen is detached and can now be replaced.
Conclusão
4 outras pessoas executaram este guia.
Brandon
Membro desde: 02/15/17
602 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membro de USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
Membros da 3
Autoria de 4 guias
4 comentários
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Responder
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Responder
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 73
Duração total: 8,030
