Ir para o conteúdo principal
PowerShot G7 X Mark II Front Cover Replacement
O que você precisa
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: passo 1, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: passo 1, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: passo 2, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 2, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove one 3mm screw on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: passo 4, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 4, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: passo 5, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 5, imagem 2 %32
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: passo 6, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 6, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: passo 7, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 7, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: passo 8, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 8, imagem 2 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 8, imagem 3 %32
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: passo 9, imagem 1 %32 PowerShot G7 X Mark II Front Cover Replacement: passo 9, imagem 2 %32
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: passo 10, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: passo 11, imagem 1 %32
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: passo 12, imagem 1 %32
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
Conclusão
Brandon
Membro desde: 02/15/17
602 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membro de USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
Membros da 3
Autoria de 4 guias
Um comentário
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 43
Duração total: 3,868
