Ir para o conteúdo principal
PowerMac G4 M5183 Graphics Card Removal
O que você precisa
  1. PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: passo 1, imagem 1 %32 PowerMac G4 M5183 Graphics Card Removal, Opening PowerMac G4 M5183 Case: passo 1, imagem 2 %32
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Pergunte ao FixBot
    Comentar
  2. PowerMac G4 M5183 Graphics Card Removal, Graphics Card: passo 2, imagem 1 %32 PowerMac G4 M5183 Graphics Card Removal, Graphics Card: passo 2, imagem 2 %32
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
13 outras pessoas executaram este guia.
Justin Petrilli
Membro desde: 01/21/10
3.204 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 13-24, Maness Winter 2010 Membro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membros
Autoria de 37 guias
2Comentários do guia
Do I need to avoid static to protect the board?
Jim Robson - Responder Compartilhar
Es ist eine deutsche Anleitung, aber auf der iFixit Übersicht als Englisch gekennzeichnet.
Toni Makkaroni - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 51
Ao todo: 10,422
