Ir para o conteúdo principal
PowerLead Puto PLD003 Zoom Button Replacement
O que você precisa
  1. PowerLead Puto PLD003 Zoom Button Replacement, Side Panel: passo 1, imagem 1 %32
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Zoom Button Replacement: passo 2, imagem 1 %32
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Zoom Button Replacement: passo 3, imagem 1 %32
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Zoom Button Replacement: passo 4, imagem 1 %32
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: passo 5, imagem 1 %32 PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: passo 5, imagem 2 %32
    • Remove the 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Zoom Button Replacement: passo 6, imagem 1 %32
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Zoom Button Replacement: passo 7, imagem 1 %32
    • Apply pressure to the back panel, pulling away from the camera to remove it.
  8. PowerLead Puto PLD003 Zoom Button Replacement: passo 8, imagem 1 %32 PowerLead Puto PLD003 Zoom Button Replacement: passo 8, imagem 2 %32
    • Remove the final 4 mm Phillips #1 screw holding the screen in place.
    • This screw is very small and hard to see.
  9. PowerLead Puto PLD003 Zoom Button Replacement: passo 9, imagem 1 %32
    • Carefully apply pressure away from the camera to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the zoom button easier.
  10. PowerLead Puto PLD003 Zoom Button Replacement: passo 10, imagem 1 %32
    • Remove the three 4 mm Phillips #1 screws holding the top panel in place.
  11. PowerLead Puto PLD003 Zoom Button Replacement: passo 11, imagem 1 %32 PowerLead Puto PLD003 Zoom Button Replacement: passo 11, imagem 2 %32
    • Push upward on the top panel to remove it from the body of the camera.
  12. PowerLead Puto PLD003 Zoom Button Replacement: passo 12, imagem 1 %32 PowerLead Puto PLD003 Zoom Button Replacement: passo 12, imagem 2 %32
    • Remove the two 4 mm Phillips #1 screws holding the circuit board in place.
    • Do not remove the silver screws.
  13. PowerLead Puto PLD003 Zoom Button Replacement: passo 13, imagem 1 %32
    • Lift the circuit board out of the plastic casing.
    • Gently pull on the zoom button to remove it from the circuit board.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 268
