Ir para o conteúdo principal
PowerLead Puto PLD003 Tripod Clip Replacement
O que você precisa
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: passo 1, imagem 1 %32
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: passo 2, imagem 1 %32
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: passo 3, imagem 1 %32
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: passo 4, imagem 1 %32
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: passo 5, imagem 1 %32 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: passo 5, imagem 2 %32
    • Apply pressure upwards to remove the tripod clip.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 220
