Ir para o conteúdo principal
PowerBook G4 Titanium Onyx RAM Replacement
O que você precisa
  1. PowerBook G4 Titanium Onyx RAM Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  2. PowerBook G4 Titanium Onyx RAM Replacement: passo 2, imagem 1 %32
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  3. PowerBook G4 Titanium Onyx RAM Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
  4. PowerBook G4 Titanium Onyx RAM Replacement, RAM: passo 4, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
Conclusão
4 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 635 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 7,312
