Introdução
The motherboard - which includes all ports and the DC-In board - is fairly easy to change.
O que você precisa
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
Pull the RAM chip out.
Repeat this process if a second RAM chip is installed.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
You don't actually have to bend the EMI clip. You can use a 2mm or smaller slotted screwdriver to pry the clip up and out.
Sugar Fish was dead-on about using a 2mm slotted screwdriver! But I must say, I’m not sure why this step is here at this point in the guide. I went ahead and removed the clip back in Step 4, after having removed the RAM, with no adverse issues.
Turn the G4 over.
Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
Remove the single T8 Torx screw located near the silver heat pipe.
Disconnect the three indicated connectors from the logic board.
Disconnect the orange PC card cage connector from the logic board.
They aren't kidding about the "large multi color" cable. A pair of hemostats and very careful wiggling will do it - NB: the lower portion of the plug, the white plastic holding the pins upright and separate, actually came significantly up, almost off - watch for that and (carefully, of course) gently press it back down - it sits flush on the board surface.
Disconnect the indicated connectors from the logic board, removing tape as necessary.
Two other connectors need to be disconnected before you can take out the logic board. One is the power connector which is out of the frame of this photo to the bottom right. The other is the audio connector, out of the frame of this photo to the bottom left, on the left side of the board.
6 outras pessoas executaram este guia.
