Introdução
How to remove the hard drive, along with its cable and bracket from your computer.
O que você precisa
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
4 outras pessoas executaram este guia.
