Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
How to replace the non-standard DVD drive. Upgrading to a newer drive requires special brackets and cables.
O que você precisa
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
5 outras pessoas executaram este guia.
