Ir para o conteúdo principal
PowerBook G4 Titanium Mercury Airport Card Replacement
O que você precisa
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  1. PowerBook G4 Titanium Mercury Airport Card Replacement: passo 2, imagem 1 %32
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Mercury Airport Card Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
  3. PowerBook G4 Titanium Mercury Airport Card Replacement, Airport Card: passo 4, imagem 1 %32
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
Conclusão
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 13,226
