Ir para o conteúdo principal
PowerBook G4 Titanium DVI DC-In Board Replacement
O que você precisa
  1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: passo 1, imagem 1 %32 PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: passo 2, imagem 1 %32 PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: passo 2, imagem 2 %32
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: passo 3, imagem 1 %32
    • Disconnect the large DC-In connector from the right side of the logic board.
  4. PowerBook G4 Titanium DVI DC-In Board Replacement: passo 4, imagem 1 %32
    • Remove the two T6 Torx screws from the DC-In board.
  5. PowerBook G4 Titanium DVI DC-In Board Replacement: passo 5, imagem 1 %32
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
Conclusão
4 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
636 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 15,253
