Introdução
Remove your memory door to access the RAM chips.
Ferramentas
Peças
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Uma outra pessoa concluiu este guia.
