Introdução
Replace your sound card to regain audio functionality.
  1. Use your thumbs to push the two battery retaining tabs away from the battery. The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. Lift the memory cover slightly and pull it toward yourself to remove it from the lower case. Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. Remove the following ten screws:
    • Remove the following ten screws:
      • Two 14.7 mm shouldered Phillips.
      • Three 12.3 mm Phillips.
      • One 3.8 mm T8 Torx.
      • One 6.8 mm T8 Torx.
      • Three 1.3 mm Phillips.
  5. The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip. Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  9. Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  10. Depress the display latch release button and open your display. Depress the display latch release button and open your display.
    • Depress the display latch release button and open your display.
  11. Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught. Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
  12. Use the flat end of a spudger to pry the sound card ribbon cable connector up off the logic board.
    • Use the flat end of a spudger to pry the sound card ribbon cable connector up off the logic board.
    • Move the sound card ribbon cable away from the face of the hard drive.
    • It is not necessary to disconnect the sound card ribbon cable from the sound card.
  13. Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
    • Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
  14. Remove the following four screws: Three 11.1 mm T8 Torx.
    • Remove the following four screws:
      • Three 11.1 mm T8 Torx.
      • One 3.9 mm T8 Torx.
    • Lift the hard drive out of the lower case.
  15. If necessary, remove the strip of tape covering the speaker cable.
    • If necessary, remove the strip of tape covering the speaker cable.
  16. Pull the speaker cable connector straight up to disconnect it from the sound card.
    • Pull the speaker cable connector straight up to disconnect it from the sound card.
  17. Remove the two T8 Torx screws securing the sound card to the lower case.
    • Remove the two T8 Torx screws securing the sound card to the lower case.
  18. Use the flat end of a spudger to pry the USB sockets away from the left edge of the lower case.
    • Use the flat end of a spudger to pry the USB sockets away from the left edge of the lower case.
  19. Lift the sound card slightly out of the lower case, minding the fragile lower portion holding the microphone connector.
    • Lift the sound card slightly out of the lower case, minding the fragile lower portion holding the microphone connector.
    • The sound card is still attached to the PowerBook by the microphone cable.
  20. Pull the sound card ribbon cable straight away from its socket on the sound card.
    • Pull the sound card ribbon cable straight away from its socket on the sound card.
  21. Use your fingernails to pull the microphone connector straight away from its socket on the sound card.
    • Use your fingernails to pull the microphone connector straight away from its socket on the sound card.
Conclusão
3 outras pessoas concluíram este guia.
Documentos anexados
Walter, is the sound out 1/8” jack located on the sound card? Thanks.
DesertMac - Responder
Found one on ebay with a good picture of the jacks. Thanks.
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 3,010
