Introdução
Replace a worn out battery for longer intervals between recharging.
O que você precisa
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Documentos anexados
Um comentário
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
