Introdução
All you need to remove the battery is your fingers!
O que você precisa
Orient the computer so that the side with the line of screws on it is away from you.
Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
Lift the battery out of the computer.
Quase terminado!
Conclusão
4 outras pessoas concluíram este guia.
