Introdução
Beyond the battery, RAM is the easiest component to upgrade.
O que você precisa
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
28 outras pessoas executaram este guia.
