Introdução
This guide shows the hidden screws you must remove when replacing the backlit keyboard.
Ferramentas
Peças
Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Peel back the black plastic shielding on either side of the keyboard (there are two pieces).
11 outras pessoas concluíram este guia.
