Introdução
How to remove the hard drive, along with its cable and bracket from your computer.
O que você precisa
Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Remove the three long silver Phillips screws from the retaining bracket on the left side of the optical drive.
Remove the retaining bracket.
3 outras pessoas executaram este guia.
